i have a 5e3 clone that i want to tame and make a bit more like a Harvard 5f10.
looking at the schematic there doesn't seem to be much difference. i have edited a weber 5e3 layout - will this work?
http://i936.photobucket.com/albums/a...ayoutedit1.jpg
do i have to change the cap coming off v1/pin1 to 0.022uf or will it be ok with what is there (0.1uf)?
also the cathode bias resistor coming off v1/pin3 should now be 1.5k rather than 820 - what will sticking with 820 sound like? otherwise can i combine the cathode bias resistors of v1 and v2 as in the green wire connection?
and one more thing: a lot of amps use a switch to change values of these cathode bias resistors on the v1/1st triode preamp stage. can this idea be applied to the cathode bias resistors of other tubes? ie. power tubes with a switchable bias resistor? or the next 12ax7(v2)?
is this what is going on in the angela schematic with the "vox twang switch" on the 6v6 here - Angela Super Single-Ended 6V6 Guitar Amp Project
