Dual DC power supply from AC heater
  • Dual DC power supply from AC heater
    I want to make dual DC supply voltage for operational amp (about +-12V) using voltage doubler from 6.3V AC valve filament without center tap.
    It isn't problem, but what about right grounding method AC heater voltage for minimal hum ?
    Because of in this case I think one AC heater side have to be connect to ground.
    Here is schematic:
    But what about grounding AC filament F1 - F2 without center tap (original circuit uses it) ?
    Add next 100R resistors or pot to ground?
    casinolevant levant casino
