I'm looking for a rocker switch that is DPDT. Typicall a DPDT has 2 commons that connect to either the "top" lug or the "bottom" lug... I'm speaking of an on-on arrangement. I've yet to use an on-on-on arrangement. I know this means that there is a "center" position - but does it also mean that the common is connected to both the "top" and "bottom" lugs simultaneously? If so that's what I'm looking for.
DPDT on on on
also anyone know where can find one? Seem hard to find through typical vendors. Ideally it'd be snap-in, and circular in shape, but I can compromise. Found this at mouser but it's pricey and looks cheap. http://mouser.com/Electromechanical/...+on+on&FS=True
The kind of switch typically meant by on-on-on is a three position DPDT where the two poles are configured like this:
Pole1: OFF ON ON
Pole2: OFF OFF ON
I.e. in the "down" position, both poles are off, in the center one is on and the other off, in the "up" position both are on.
This can be configured to work like a single pole triple throw switch somehow (I can't quite recall how, but I think it would be shown in the data sheet).
The other thing on-on-on can mean is one end is on one way, the other end is on the other way, and in the center both ends are on. An example of that is a pickup switch on a guitar - one way for neck, other way for bridge, and middle for both.
What is it for lowell?
The progreesive on switch is sometimes used for a single switch serving both power and standby. is that it?
Dave West sells those for $12.
West Laboratories Guitar Amplifiers Look under parts, then switches.Education is what you're left with after you have forgotten what you have learned.
I looked at that Mouser link, and the data sheet shows the switch as a On-off-On DPDT. On-On-On is made by using an external connection.
I've used those for reversing the line of a power transformer. Just form an "X" with the contacts and put the line on the poles.Now Trending: China has found a way to turn stupidity into money!
The On-On-On configuration is usually only available in Toggle switches. There is a "Rocker" type available, it's really a toggle switch with a rocker type actuator. Mouser P/N 611-7211J26ZQE22 . Look at the page from the data sheet below, type 7203 is the conventional On-Off-On type and the 7211 is an On-On-On. Note on the right side it shows how the terminals are connected in the three actuator positions.
You can't make an On-On-On from a On-Off-On with external connections.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Ok yeah LT that's the one I was referring to as well. I guess I'll try it and see if I dig it.
Enzo it's for power tube selection. I want "up" to be one pair, "down" to be the other, and "center" to be all tubes. See schem below.Attached Files
Then go to the switchmakers web sites and start looking for on-on-on configurations. if you find something suited, then you at least have a part number. CArling for starts.Education is what you're left with after you have forgotten what you have learned.
Originally posted by loudthud View PostYou can't make an On-On-On from a On-Off-On with external connections.
http://www.nkkswitches.com/pdf/MLW.pdfLast edited by guitician; 01-21-2010, 04:31 PM.Now Trending: China has found a way to turn stupidity into money!
