I'm trying to line up a few things for my next project and have been investigating some ideas based around using some power tubes I have on hand. Namely a couple of Svetlana 6550Cs and a couple JJ 7591Ss.
While looking at tube data sheets for plate load readings, I noticed some odd things. Odd to me at least. Time for my next lesson in the wonderful world of tubes I guess![Big Grin](https://music-electronics-forum.com/core/images/smilies/biggrin.png)
It seems that the plate-to-plate load ratings change based on a number of things like the plate voltage, fixed vs cathode bias, ultralinear vs not.
It's making it tricky to try and match an OT to possible intended uses for these tubes.
For example, the 7591s seem to list 6.6k load for two tubes in a PP circuit...except when the plate voltage is at 450v and cathode bias. Then it shoots up to 9k. But it does list a 6.6k load for a cathode bias config at 425v plate volts running ultralinear at a 40% tap. I'm looking at Tung-Sol data sheets, BTW. The JJ sheets are nowhere near this detailed. The 6550s are even more all over the place.
What all affects the plate load readings and how do you figure what they would be for a given set of conditions? Or is it something you just have to put together and measure?
As you can tell, I'm a little confused on this subject
![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
