Wattage Measurements
  • Wattage Measurements
    I’ve used a scope and a dummy load on many occasions to determine if an amp is working properly and is putting out its rated power. I’ve made a spreadsheet that converts the AC voltage at the load box to watts, based on whether the box is set for 4 or 8 ohms.
    I’m wondering if I’m doing this correctly. Should my calculations be based on the dummy load’s resistance or the resistance rating of the output transformer? Using a blackface Bandmaster with a 4 ohm output transformer as an example, and connected to an 8 ohm dummy load, should I base my calculations on 4 ohms or 8? And does the mismatch effect the amps ability to put out full power?
    Use the value of the load that is connected. There are some speaker cabinets that are rated at 6 ohms (they're actually 5 2/3 ohm). If you want to know how your amp will perform, connect a 6 ohm load, measure the voltage and use the E squared over R formula to know how much power your amp will produce with that load.
    Tube amps will typically deliver more voltage into higher impedance loads. Solid state amps, not so much.
