Replacing 6N7 with 6SL7?
  • Replacing 6N7 with 6SL7?
    I have a very old PA amp that I'm using as a guitar amp. I'm planning on replacing a 6N7 in the preamp with a 6SL7. The max plate voltage ratings are the same and I know the pinouts are different. Is there anything else I need to watch out for or do?
    Also, what would be a higher amplification replacement for a 6SJ7? If I can find a suitable replacement, I'll switch that one out too.
    Thanks,
    Don
    I heartily recommend trying a 6AU6-A pentode; all the gain & slam of an SJ7 but better shielding and lots available cheap NOS!! here's one I built with one:
    http://www.retrodyne1.com/29Wamp.html
    shielded NEW ceramic sockets available at Triode Electronics, Chicago IL. Plus they have some inexpensive iron worthy of trying too.
    HTH,
    Alexander
    Cheers,
    Alexander
    Austin Texas
    www.retrodyne-austin.com
      Hey SS.
      Do you have a schematic or have you diagrammed out your amp? The 6N7 was designed as a driver and not a voltage amplifier - possibly as the phase inverter. The 6SL7 has a much greater mu but no where near the power dissipation. I don't know squat about your particular amp but if it in anyway approaches class AB2 with the N7 driver then the SL7 won't work. While I seem to remember a few amps that used the N7 as a preamp this would put your design either at the late 30s/early 40s or one that used the N7 due to WWII materials restrictions - does it have metal 6L6 outputs?
      Rob
        Yep, here's the schematic (I eliminated the shaded area). I'm a newbie at this, but I believe that the 6N7 is used as a voltage amplifier. The circuit uses a transformer as a phase inverter. This circuit is indeed from the early 40's. The 6N7 is set up in a grounded cathode configuration (class A stage, correct?). The amp likely came with metal 6L6's (push-pull class A), but they were glass when I got the amp.
          HTH,
          Alexander
          Nice looking amp! I'd rather not change to a 9-pin tube, though. I'd prefer to stay with the octals in this amp - keep it as "period" as possible.
          Don
