You may have seen this before: 18-Watter Buzz Info
Re the value of the zener, he writes: "The trick is to chose a zener value to clip the grid signal somewhere beyond the tube cutoff grid voltage." Which he dtermined in his amp at 7volts.
My question is, How do you determine the grid voltage at cutoff? Is it as simple as scoping the output, slowly increasing the Volume until the tube goes into cutoff, and measure the ac voltage at the grids? I don't know how he got those scope shots of the grids showing the clipping on the positive swing and the deep negative swing.
