Many times when I measure a brand new (or known good) OT primaries, they don't measure exactly the same...i.e. the dc resistance of one primary 'end' to the center tap will be slightly more/less than the other.
Usually it seems that the out-of-phase signal of a PI is stronger than the in-phase signal (relative to the PI input signal)...or at least the power tube driven by the out-of-phase signal is working harder (verified by the highly scientific method of watching the tubes 'light up' as I play it hard ).
So...which is better...driving the 'higher resistance' side of the OT with the stronger PI signal or driving the 'lower resistance' side with the stronger PI signal. This means taking into account the NFB (if any) and swapping the PI/OT primary leads to get that part right.
