I'm planning to build a new guitar amplifier and I'm thinking to go with KT66s.
I dig the sound of blonde Fenders like a Bandmaster or Showman. So I need a clean with a lot of headroom sound!
I have put some KT66s in Fender clones and the results were more than pleased! But these tubes need their own biasing to give their best.
Does anyone have any experience with KT66? Any advice before ordering the parts?
To start the discussion I'll write down what I have in mind.
First of all, I'm planning to use one pair of Genalex Gold Lion. A good choice from a lot of builders.
I'm planning to use an OT with 6K6 primary impedance. It's something between 4K and 8K. Neither too low or too high. Marshalls with KT66 are using 8K but the results with 4K in Fenders are great, too. So, I'd like to go somewhere in the middle. Any opinions over here?
Also, I'm not sure with the anode voltage. From KT66's data sheet, they don't have any problem with 500V or a little bit higher. But I don't like to go at these levels. What about 480V?
And what do you say for the Screen voltages? I read somewhere that with lower screen voltages like 400V are much more better. Sweet clean sound with much more headroom. I can feed the center tap before the choke and the screens after the choke with 1K screen resistors and CRC filtering. Then, I can choose the right resistor for 400V on the screens or experimenting with different voltages at this range.
But I'm pretty curious for lower HT voltages, too. As watts are not my main goal I don't mind if I'll use a lower HT. Let's say, 400V or even lower and have the advantage to drive the output tubes with higher currents. If KT66s sound better like this it's no problem to lose some power. I'll be ok, even with 30W total power!
I'll use a well filtered fixed bias to drive the tubes hotter or colder and keep the bias I prefer. Maybe with separate pots so I can balance them or unbalance if I like! Two 1 Ohm resistors will be permanently at the cathodes so I can adjust the bias with an external DMM.
Please, any advice will be great! I have almost all the parts except the transformers!
I'm waiting your opinions! Thanks for your time!
