For small amps intended for power amp distortion I like to have a stiff B+ supply- somehow it makes sense and I generally like the sound of it.
If I'm building a larger/higher power amp with KT88's or 6550's, do I really need that kind of plate voltage regulation? I don't intend to crank up a 100 to 200 watt bass or PA power amp up enough to create significant power tube distortion so how much reserve current do I need?
I have a PT from an old television that produces 800vct and about 8 amps of filament current. The PT secondary is about 40 DC ohms from end to end. It's a bit bigger than a Silverface twin PT I have laying around. I've spent enough time with Duncan's power supply designer and a volt meter to know it'll probably do well running a 100 watt tube amp with two 6550's or the like.
I have filament current to spare- so should I even bother to try it with four large output tubes? In power supply designer it makes about 530v at 200ma and 500v at 400ma...probably a good match for two pairs of KT77's or a pair of KT90's but I'm curious what others opinions on the subject might be.
Maybe 4 cathode biased KT88's?
I'm 90% certain it's going to end up in an amp with a pair of big output tubes and a 5k/3.5k potted output I have laying around but I thought I'd get some other opinions.
jamie
jamie
