I built an BF-style amp with a 5k2 ohm OT. I'd like to use it with both 6L6s or 6V6s (transformers are beefed enough and bias can be adjusted).
I believe the OT is in the impedance range for 6L6, not really for 6V6.
With 6V6 should I set OT's output to achieve a reflected impedance of 10k4 ohm?
In other words: is it better to run 6V6 at 5k2 or 10k4 OT impedance?
Thanks in advance
Thanks in advance
