I completed my AC30 inspired amp yesterday, and I decided to go with DC elevation for the heaters instead of just referencing them to the top of the cathode bias resistor (because of the cathode-lift standby scheme, it would cause problems).
I used what I had on hand and ended up with a 220k/68k divider (both 2W) which gives me about 75V of elevation (jumps to 90V on standby).
For the cap across the 68k resistor, I didn't have any small electrolytics left, so I used a .1uF poly cap I had left.
Should the cap be bigger than that? There is almost no current going through there and it's a constant load, I'm not even sure I understand why the cap is necessary.
As for the elevation. Is the 90V on Standby too much? The preamp tubes are still working on Standby.
I see the cathode follower stage has the cathode floating at 134V on idle, so DC elevation is really not a bad thing here!
What happens if the filaments are floating too high? Will they start acting like the anode and start drawing electrons?
