I've spent many hours this weekend plotting the voltage and current output of my collection of power transformers from various tube gear I've taken apart over the years. I'm trying to establish reasonable current ranges for each based on the voltage drop at different currents.
I understand that heat is often the limiting factor but I've been surprised at how little some of the transformers heat up even when they've been loaded past what I would call "normal" voltage regulation.
The Fender Twin Reverb and Vibroverb transformers I tested both show about 5-6% regulation from "resting" voltage and current to a load I would consider to be "full load." Is this the standard value for class AB1 guitar amps? Do Marshall or Vox parts perform similarly? I ask because I have none of my own to test.
Is there a traditionally accept percentage regulation I should shoot for? Should this value change with the operating class or intended use of the amplifier?
Should I have already read the answer in RDH4?
Seriously though- I'm looking more for real-world advice, not so much the textbook answers.
jamie
jamie
