cathode bypass calc. what am I doing wrong?
  • cathode bypass calc. what am I doing wrong?
    The Single Ended Output Stage article on MerlinB's website gives the following formula for calculating the bypass capacitor value:
    Ck=1/(2*pi*f*Rk)
    using the values in his example circuit this is
    Ck=1/(2*pi*10*220)
    =72uF
    72uF=0.072F, correct?
    but when I do the calculation (using the calculator utility in Windows) I keep getting 7.2xxxxxxxxxx (rounded off to two places) rather than the expected 0.072
    I am off by a factor of 100 and I can't see why.
    Also, I solved the same equation for f and get
    f=1/(2*pi*Rk*Ck)
    Is this correct?
    Thanks, it's been a loooong time since High School Algebra!
    No. A microfarad is one millionth of a farad, so 72uF = 0.000072 farad
      Are you sure there isn't an "e-5" at the end of those numbers? (Which means x10^(-5) )
        Yes there was. I didn't know what it meant, and thought it was some sort of error message due to more places than the calculator could manage or something.
        so one micro = 0.000,001
        and one pico = 0.000,000,000,001
        does one nano = 0.000,000,001 ?
        Did I solve for f correctly?
          think so,
          1pF = 0.000000000001 F = 1e-12 F ( see why they use the e?)
          1nF = 0.000000001 F = 1e-9 F
          1uF = 0.000001 F = 1e-6 F
          1mF = 0.001 F = 1e-3 F
          some use mF to mean "micro" farad, or even mmF to be millimicro farad
          micro is a greek "mu" and windows makes it an "m" as an english character...messes people up!
          oh, a zeptofarad is e-24!
          chemistry joke: 1.660538863zM = 1! (not factorial, although that works too)
            Yes.
            f = 1/(2 pi R C)
            is like Ohm's law for filters, commit it to memory!
              one more question for you Merlin (or others)
              That is a very simple formula compared to the formulae in the "Choosing Cathode Bypass Capacitors" article by you and David Ian James.
              What neccessitates the higher complexity of the information and formulae in that article?
                Mental masturbation
                just do this ... it's an old ham radio trick for -3dB points in a simple RC circuit:
                159160/ RC = Fz
                example:
                R = 1500 ohms
                C = 10uF
                1500 x 10 = 15000
                159160/15000 = 10.67Hz
                here's your circuit the ham radio way to find Fhz at -3db
                10 x 220 = 2200
                159160/2200 = 72.3Hz
                Bruce
                Mission Amps
                Denver, CO. 80022
                www.missionamps.com
                303-955-2412
                  Is this formula {f=1/(2piRC)} the same for all filter configurations?
                  The way I see it there are at least 3:
                  R in parallel with C
                  R in signal path and C to ground
                  C in signal path and R to ground
                  I suppose the answer is in the book, actually.
                    Yes. It works for CR and RC. In the case where you have a resistor in parallel with C then you need to find out what the source resistance is, and you imagine this to also be in parallel with the cap.
                    That is a very simple formula compared to the formulae in the "Choosing Cathode Bypass Capacitors" article by you and David Ivan James.
                    That's because cathode bypassing is dealing with small amounts of negative feedback, which greatly complicates things. The simple formula becomes an approximation, but it's close enough for rock and roll.
