Considering the grid circuit of a typical capacitor-coupled common-cathode triode stage, the AC signal runs through the grid load resistor to ground, but I am trying to envision what effect the grid stopper has on the AC signal amplitude at the grid.
Since the grid is not internally connected to anything there would be no current flow through the grid stopper except when the grid voltage approaches the cathode voltage and grid current flows, and so according to Ohms law there would be no voltage drop and the AC amplitude would be the same on both ends of the grid stopper.
But my intuition tells me you can't have a resistor in the path without giving something up. So therefore it seems like the grid stopper and grid load would interact in some way to act as a voltage divider, and the AC voltage at the grid would be lower than the AC voltage at the grid stopper and grid load junction.
Who is right, me or Senor Ohm?
The same question might apply to screen grid stoppers. I think it is also why I am a little puzzled about how to inject bias tremolo into the output stage of a cathode-biased push-pull amp.
This is a specific subset of my general lack of understanding about ground reference circuits, which also seems to come into play in figuring out
