Hello,
I recently picked up an amp that was an old Italian guitar head. Ridiculously large cabinet, and it used a pair of EL503s which are far out of my price range to replace. The transformers appear to be of very high quality at least. The power transformer secondary has a 290-0-290 winding, a bias supply for the El503s which is around 25V, and ss diode rectifiers, so just a 6.3(around 4amps) winding. The output transformer is a bit on the strange side. I've got the standard three wires on the primary, which when used as I got it showed 2k5@16ohm on the secondary. The secondary has a total of five wires. Two wires are a separate secondary winding which reflect around 6k@8ohm. The third unused wire is on the same winding as those used originally and one connection has 8k@4ohm, while the other has 5k@16ohm.
I'm open to ideas at the moment but my preference is probably something that's cathode biased (I'm not so keen on putting a new bias trafo in). If anyone has a suggestion on an output tube pair that would fit these ratios/voltages it would be much appreciated.
My first inclination is to try something with a pair of 6L6s at 380VDC into 5k winding. I would think they are better suited to the lowish voltages than say an EL34 but that may just be my lack of experience...
