Originally posted by tubeswell
View Post
Ground loops aren't harmful by themselves: you only hear hum when the current induced in a ground loop flows in a path where the IR drop due to it can add to the signal. And this is probably the same mechanism you call backwobble.
Studio wiring is full of ground loops, but because it's balanced, the ground currents can't get into the signal.
And likewise the ground current needed to cause a "backwobble" can come from somewhere else than a ground loop. The classic case being the center tap of your power transformer.
I don't really hear the ghosting Dai mentioned, it just sounds like a stinking loud Marshall to me.
