I am still twiddling with the revamped model. (Note that it will have separate filter caps including an extra 22uF 450V).
Before I sling it back together again, I had this idea (based on Merlin's grounding article) about grounding the pre-amp (V1a and V1b) and reverb recovery at the same decoupling cap (cap 1), and grounding the PI driver and PI at the same decoupling cap (C2), and grounding the 'spare' coupling cap (C3) together with C1 and C2 at the input jack ground. I an left wondering if there is anything else I should do in bringing the grounds of cap1, cap2 and cap 3 together at the input jack ground?
The reverb driver circuit and the LFO circuit would ground together at the screen filter cap. The screen cap and the reservoir cap and the HT, and the heater voltage divider/bleeder resistors, and bias supply would ground together.
See attached schematic for the pictoral definition. Any opinions welcomed please.
