I'm reworking a build to closely follow Merlin's excellent scheme which has been floating around here for a bit- thanks Merlin, book order shortly following!
My question pertains to his initial connection to the "reservoir" cap. I'm pretty sure he is presuming a bridge rectifier, sans center tap. The transformer I'm using is a fender-style that has one. If I'm correct, the center tap forms that lower leg and must, to work with this scheme, be connected at the base (-) of the res cap forming the reservoir gnd point.
Am I on the right track? I'm using a bus wire from the input Jack, Where the bond is made, back to a main spur and the res ground, per Merlin, and a mains earth right off the plug, unconnected to anything else, also per big M.
Thanks forum!
Thanks forum!
