Hello all,
I'm in the process of designing a new amp for a friend of mine. I already built a similar one in head format: KT77 no-nfb power stage, 12AT7 LTP, post-pi master volume, GZ34 and a 2 stage preamplifier like this
http://users.telenet.be/orangefg/OFG...Cmainboard.pdf
the upper one (slightly less gainy than the lower one).
The owner likes the sound VERY much, so asked me to build another one in combo (1x12") format. My idea was to replicate identical electronics as the other amp (maybe with a little lower B+ and little less beefier transformers, for weight and early breakup), BUT I would like to add another "channel" based on a pentode (maybe EF86) that goes to the other (unusued) input of the LTP to mix the two channels (and to allow "bridging" of the two). This "other" pre will share only the master volume with the standard one, so I would like it to have gain and a single knob "tone" (or a rotary selector maybe?).
So, what would be a good circuit to obtain a VERY DIFFERENT sound from the 2 stage 12AX7 preamplifier of the normal channel? I would like something very compressed, fizzy, nasty, to be different than the relative "cleaness" of the 12AX7 based pre...
And also, a little bit OT, with those circuits in mind, what would be a good speaker? My friend likes the Fender Blues Junior tone, dislikes his G12H based closed back cabinet, sort of likes the Vintage 30 but think it's too bright. I'm oriented toward an Eminence Red Coat series.
