Heya I'm new to this so I hope this isn't too stupid a question.
I'm designing a roughly 10-20W, all valve amp from scratch. I'm a Mechanical engineer by trade, but thought this would be a great opportunity for me to flex some design and manufacture muscles I haven't in a while! BUT I'm having problems now, starting to source components and the like.
Attached you can find a simple schematic of my preamp stage as it stands.
Found MAX and TYPICAL data for the 12AU7s i'm putting in, but can't find anywhere near the detailed tables like the one I've posted as an example. How do I use the graphs they often give? I want to know how to vary and quantify the plate, coupling and cathode resistor/cap values when I'm varying the valve voltage.
I've attached an image to clarify what I am naming there...
Anyone got any ideas as to where to look for these?
I'm planning on using JJ Electronics 12AU7s and so on for now as I get the circuitry down and then switch for something better. Heard reliable things about them.
Hope someone out there can help!
