I'm trying to figure out why blocking distortion is clipping the top off the signal & clamping the input at only +5v when the bias is 11.8v (B+ is 308v).
The UL-configured EL84's are drawing only 75mA at quiescent.
The attached jpg of scope traces are from both sides of the same 68k stopping resistor. I'd increased that from 4k7 to 22k to 68k and although it helped, it hasn't fixed it.
The PI is a 12au7 cathodyne, drawing ~4mA. The signals are as clean & balanced as I could hope for.
The coupling caps are .047uF and the grid resistors are now 75k (were 150k)
Any suggestions are welcomed - thanks in advance!
