A question came up on another amp board I was visiting today, and I thought I would bring it here to see if I could get a better answer than what I am getting over there. No argument going on, I'm just not getting a very technical answer to the question.
If an amp is set up with multiple impedance speaker jacks, say 4, 8 & 16 ohms, each one connected to the corresponding tap on the output trans, what is the effect of running loads on two of the taps simultaneously? I.e., say a 4 ohm load on the 4 ohm tap and a 16 ohm load on the 16 ohm tap.
The typical response is no, you can't do that, but without a good explanation of why not. Since I like to understand why not, I wanted to press for a better answer. It seems off hand that the each load would present the correct load back to the primary, perhaps with the result being similar to running parallel loads on a single tap with the total primary load being halved. Is this completely wrong? Can anyone explain it?
Thanks
Hasse
Thanks
Hasse
