I guess the question then, Gary, is this: If you have a 16 ohm speaker on the 16 ohm tap and the amp running at rated output. Does adding a second speaker - say an 8 ohm speaker on the 8 ohm tap - change anything on the primary side? If it does, then the two loads have added. If it doesn;t change anything, then we get free power to one of the speakers.
And we know that if we connect a 8 phm speaker to the 8 ohm tap of a 50w amp, we get 50w in the speaker, and if we instead connect two 16 ohm speakers in parallel to that tap, we still get 50w, but 25w in each speaker. SO, starting anew, if we connect a 16 ohm cab to the 16 ohm tap and get 50w, and then an 8 ohm cab is added to the 8 ohm tap, then either the added speaker gets 50 free watts and the 16 still gets 50 watts. Or the two speakers now split the 50w between them for the same 25w each. If that split happens, then by not touching the 16 ohm speaker, we can change the power to it by plugging the 8 ohm speaker into the 8 ohm tap or not. And the only way that can happen is by the load on the tubes changing.
