I'd like to compare a choke input w/ a resistor input. My choke is 5H w/ 100ohms DC resistance. I'd like to listen to my amp w/ the choke vs a 100ohm resistor. Here's my question. If I hardwire the resistor, can I switch the choke in "across" the resistor and it will swamp out the resistor? Or do I need to disconnect one end of the resistor when switching in the choke?
2nd Q: Does DC resistance of a choke change as it current is drawn through it?
