If a take a 40 watt tube amp and plug the 4 ohm output into an 8 ohm speaker, how much power reduction (in watts) will I see at the speaker?
switching 8 ohm to 4 ohm output-output power reduction??
When doubling the load you'll see a 50% reduction in power (which theoretically equates to only a 3dB reduction in perceivable volume), but the screen current on your tubes will increase as well.Jon Wilder
Wilder Amplification
Originally posted by m-fineI don't know about you, but I find it a LOT easier to change a capacitor than to actually learn how to play wellOriginally posted by JoeMI doubt if any of my favorite players even own a soldering iron.
So, its a maz 38 which is split cathode biased, so the bias should be cool too. I run it with a Celestion G12h-30 (30 watts) 8 ohms, so I may use the 4 ohm output if I have to crank it up so i dont damage the speaker. Thanks.
Keep in mind that 50 watts is the rated CLEAN power. Amplifiers put out much more than their rated clean power when cranked into clipping.Jon Wilder
