First, let me say that this post is just thinking out loud from someone who's arrived at working on guitar amps through a very indirect route through tube Hi-Fi and Hammond/Leslie. I play enough guitar to test an amp, but I'm not a guitar player by any stretch of the imagination.
I've recently worked on two guitar amps that use quartets of EL84s, a Peavey Delta Blues and a Mesa Boogie .50 Caliber. The Mesa amp runs its output tubes at high plate voltages for an EL84: 436V according to the schematic, a bit higher in practice. The screens are also high: 360-380V, and the amp's manual mentions replacing the output tubes as often as often as every six months. It occurred to me at one point during the repair process: why do it this way? A pair of EL34s would handle those plate voltages just fine, give you about the same plate dissipation as two EL84s, and would require the same heater current. Like EL84s, EL34s are fairly easy to drive. You can squeeze 50W from a pair of EL34s--probably more effectively than you can squeeze 50W from a quartet of EL84s.
Using multiple tubes in parallel push-pull makes oscillation a potential issue, requires more tube sockets, more complex wiring, etc... and, if you care about tube matching, makes it necessary to get four matched tubes rather than two. With this in mind, I'm assuming that there's some design goal in 4 x EL84 amps that I don't quite get, and I was hoping that those of you who ARE guitar players and amp designers could tell me what it is. I know that while running clean, it can be hard to distinguish tube types, but they do sound different when overdriven. Is this the main reason? I've played the Mesa amp in the shop, and it seems to me to be capable of getting plenty of overdrive (nice-sounding overdrive, IMO) from its preamp section without having the overdrive the output tubes at all.
Thanks for helping me with my admitted ignorance here.
David
P.S. Two of my favorite Hi-Fi amps at home are my Scott 299 (7189s) and Dynaco SCA-35 (6BQ5s, rebuilt to use the ST-35 driver circuit), but both use pairs of output tubes.
David
