I like EL84s for the harmonic content when overdriven, compared with EL34s at a similar volume level. You can hear it better with a single-ended amp. The EL84 will break up earlier and give more saturation and crispness, and be more touch sensitive. If headroom and volume are the consideration, then big-bottle tubes win. Most people I work for aren't too bothered about volume because they always mic up. There's a dynamic with a small amp pushed hard that you don't get with a bigger amp where the output tubes aren't even beginning to contribue much character, because all of the distortion is from the preamp.
Tube spec sheets don't really relate much to the guitar world; the voltages are given for maximum life in a radio or piece of test equipment or whatever. I doubt whether any tube manufacturer purposely designed a tube so it would break up and distort. It's a post golden-age affectation of guitarists that would bemuse our forefathers. I was talking to an old ex-Royal Navy radio guy (totally removed from guitar amps) I buy lots of NOS tubes from, asking him about some Mullard ECC83s. He said he'd got plenty of others that were cheaper, why would I want Mullards? He was incredulous when I said it was the way they distort - "why would you want a valve that distorts?" When I began to explain he cut me off and re-emphasised "No, but why - an ECC83 is an ECC83" and then got a couple of handbooks off the shelf to present to me the specs of different brands.
Getting extended life out of tubes in a guitar amp removes most of the reason why they're in there in the first place. A bit like running a Porsche 911 around at 30mph to extend tyre life and improve fuel consumption.
