has anyone tried using a 150w 220v car inverter as a 12ax7 power supply? why or why not?
car inverters as tube power supplies
I think imaradiostar did something similar with a low wattage Class A SE amp...using the SMPS from an inverter to power it. IIRC the thing only sagged about a volt under full output.Jon Wilder
Wilder Amplification
Originally posted by m-fineI don't know about you, but I find it a LOT easier to change a capacitor than to actually learn how to play wellOriginally posted by JoeMI doubt if any of my favorite players even own a soldering iron.
These things usually work by converting the 12V supply up to 160V DC (or 320V for ones sold in 230V countries) before inverting it. So you can tap off this "DC bus". It's regulated, so no wonder it only sags "about a volt".
I expect it would have a lot of noise and hash on it that would need filtered."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
http://music-electronics-forum.com/t19365/
I haven't done much else with it. It's pretty fun, whatever the case.
jamie
Then again on a true Class A amp current draw SHOULD BE constant from idle to full output power anyway since the power supply itself sees a constant load from idle to full power output so you'd think there wouldn't be any sag whether you ran regulated or unregulated. But having no actual hands on experience with Class A SE amps I could be wrong.Jon Wilder
Originally posted by Wilder Amplification View PostThen again on a true Class A amp current draw SHOULD BE constant from idle to full output power anyway since the power supply itself sees a constant load from idle to full power output so you'd think there wouldn't be any sag whether you ran regulated or unregulated. But having no actual hands on experience with Class A SE amps I could be wrong.
I have no idea if the EMF of the speaker plays into this effect or not but some claim that it does. Kinda like an RF transmitter with a tuned output section or something like that.
jamie
