Thought I'd start a new thread for this. Say you have to make a relay supply in one day and all you got laying around are some 12v relays and the amp on the operating table has a bias tap and you don't have any suitable transformers around.
Could you connect the base of a high powered pnp mosfet to the bias supply filter cap, drain to a negative supply off the main rectifier via 1 diode and filter cap, and source through a suitable valued Rs, in voltage follower arrangement, then a filter cap on the source, then voltage divider to make 12v supply? That would take care of the "current" issue that comes with your typical PT bias tap right? Or do transistors function differently with DC than AC? Or maybe this is absurd...![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
I know there's more specifics to worry about, but is this basically accurate?
