Tried to search for the answer but the term is sometimes too widely used ![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
When you use an amp with two dedicated speaker outputs from the same OT (so for example the Orange AD200 which has 2x 4 ohm outputs and 1x 8 ohm output; both outputs (the 4 and the 8 ohm) are 'dedicated' as they originate from 2 places of the OT with a shared common ground) can I use both speaker outputs at the same time? So can I hook up an 8 AND a 4 ohm speaker to those outputs at the same time?
