2xel84 design
  • 2xel84 design
    Here is my degisn for a 2xel84 amp , any thoughts
    It will be clearer if you post the schematic, instead of a layout.
      Looks like a lite vox type amp.
      A schematic is always much better, layouts are normally done after the schematic is finalised.
      Think you may need to tame the bass a little more…. But that’s a matter of taste and which speakers you use.
        I think your preamp is biased very cold (1.5k in parallel). As well, there is no grid leak resistor on the input.
        Otherwise, I'd second what they said: no schematic makes things difficult, and no voltages doesn't help either.
        Maybe a switch to go from triode mode to pentode wouldn't hurt...
