I have a request from someone to build a stereo tube guitar amp head. Probably around 15 watts X 15 watts using el 84's.
This amp will have quite a few bells and whistles. (chanel switching on each channel) effects loops and so forth. It will be quite an amp as it will have 2 of them in one.
I realize that the more complicated the amp, the more that potential problems are compounded in the design. Hums oscillations and so forth. One thing I am particularly concerned about is the transformer placement. For example amp 1 will be on the left and amp 2 on the right of the chassis. Lets just say that the input for amp 1 will be on the left side followed by the tone stack and then the second amp input will be basically starting in the middle of the chassis followed by it's tone stack and so forth.
I was thinking of having 2 power trannys and 2 OT's.
The power tranny for amp number 1 will be basically in the middle of the chassis away from it's input but then the problem will be that it is close to the input of the second amp. Being that the power trannys will be completely mounted on the top of the chassis, will that still possibly effect the input of the second amp?
One factor would also be the size of the chassis as although I don't want a huge chassis it would have to be big enough to work properly considering the above problems mentioned.
I hope you can understand where I am coming from.
Thanks for reading the long post.
