In a typical Marshall, what does a resistor from the preamp gain wiper to ground do for the sound/tone? Does it dump some of the signal to ground, reducing the voltage to the next stage and thus the gain of that next stage? Thanks.
Preamp gain pot mod
Originally posted by Enzo View PostGo over to Geofex.com and look up the secret life of pots.
I see that it can improve the taper of a linear pot, but why would someone use it with an audio potMake an audio pot even more "audio-er"
It looks like it would serve no purpose...
If you want a gain control to cover from clean to super distorted, then to get good resolution over that range, an 'even more audio-er' pot might be just what's needed.
Also, in conjunction with a preceding coupling cap, as the gain is increased, more bottom end will be rolled off, which can be useful to avoid the sound 'farting out'. Pete.My band:- http://www.youtube.com/user/RedwingBand
There are any number of audio tapers, many are expressed as a ercentage at mid point. So I can see if an OEM wanted a different curve but alreay had a ton of these controls, the addition of a resistor costs almost nothing and serves their purpose.
There is no right and wrong in pot tapers, there is only what you want in any given application.Education is what you're left with after you have forgotten what you have learned.
I'm thinking on the same lines. The resistor could serve many functions. If it follows a cap and is right behind the target grid it's most likely a bias resistor and must be there for the circuit to operate correctly. In which case it's a bias resistor and possibly an attenuator. If there is a cap ahead of it (signal on it's way to the next grid) then it could do a few things. It could be a taper adjuster and or gain attenuator and in some cases part of a phase correction circuit.
In your amp it's most likely a gain attenuator/taper adjustment. But since there's almost no such thing as a "typical Marshall", especially with a "preamp gain" control (unless you just mean the "volume" control) it's hard to say for sure."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostIn your amp it's most likely a gain attenuator/taper adjustment. But since there's almost no such thing as a "typical Marshall", especially with a "preamp gain" control (unless you just mean the "volume" control) it's hard to say for sure.
Hmmmm, I see no resistor to gnd from the wiper in those circuits...???
Schematic:http://web.archive.org/web/200609191...l_50w_2204.pdf
