That's a good question. If you're using a voltage doubler, the 6.3V winding will be elevated, so you can't ground the CT.
Is it ok to convert 6.3v C.T. sec. to DC?
Originally posted by TransLucid View PostThat's a good question. If you're using a voltage doubler, the 6.3V winding will be elevated, so you can't ground the CT.Last edited by Wilder Amplification; 02-05-2011, 08:40 PM.Jon Wilder
Originally posted by m-fineI don't know about you, but I find it a LOT easier to change a capacitor than to actually learn how to play wellOriginally posted by JoeMI doubt if any of my favorite players even own a soldering iron.
Here's a circuit I used:
It provides 12V DC for switching circuitry while leaving the 6.3V AC heater supply centre tapped to ground.
You need pretty big capacitors, like 2200uF or more, but they're physically not that large because of the voltage rating. Runs three small 12V relays and a bunch of LEDs nicely.
(I always wondered if the circuit could be turned upside down for a free +12V heater elevation.)"Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
