I'm learning to use my scope for debugging and hoping to find a book or site that shows what causes different looking distortions. Any suggestions?
My current specific problem looks like this:
About 800Hz. Starts deforming at 1 Volt pp in and 40 Vpp out. The slope of the deformation increases as freq. goes down. If I'm using Merlin's Load Line Plotter correctly, it looks like I should be able to get 2 Vpp in?? This is a Kalamazoo amp. The input sine wave is measured at V1A pin 2 to ground and the output is at pin 1 to ground. I have made some ckt changes and my anode voltages for V1B & V1A are about 145 & 150 not 183 & 210, and my R3=1.8k, R13 =2.2k & the trem ckt is lifted out, however the problem existed before my changes.
kalamazoo_m2s.pdf
As I'm writing this, I am realizing that I should have tried a new C3. The PS caps have all been changed.
Any ideas would be great.
Thanks
kalamazoo_m2s.pdf
Thanks
