To start my foray into tube amplification, I've decided to start 'making' (more like experimenting with...) a low voltage rack pre-amp based on some dirt cheap 12U7 tubes (basically a low voltage 12au7, with a gain of 20~ and a plate max of 30v).
Sort of like an upscale distortion pedal so I can experiment with proper pre-amp topologies and the sort without killing myself, and hopefully get something I can plug into a power amp without blowing it up
Anyway... I have a high gain design in mind and was just wondering about the attenuation between gain stages, because I imagine with a 12ax7 under clipping you'd have 200v p-p flying off the plate. Knowing that it only takes roughly 4v p-p depending on where you bias to clip a 12ax7, I know some attenuation is going to occur, but my question is, how and how much for a 'high gain' amplifier? (think Mesa or ENGL's)
My second conundrum is, are more gain stages a 'replacement' for a harder clipping, higher gain triode. Realistically, the gain is only going to be about 7-10 for what I plan to run the 12U7's at, and given I have no idea about cascading gain stages, would this still sufficiently clip following gain stages?
Hypothetically, if you cascaded a hundred gain stages together without them ever coming close to clipping through attenuation, the THD would be huge, and it would certainly sound distorted, but what would happen to the dynamic level? Would it simply end up with a lack of sustain?... At least in my head this is how it would appear, which leads back to my second question.
My third and final question pertains to voltage dividers. I know that this is usually how stages are attenuated. Usually I see the grid stopper is connected after the grid leak resistor, but what would happen if it were connected before it (ie both soldered directly to the grid). I know it would form a voltage divider, but my question is, would it work? And in the case that it actually did work, how would this affect miller capacitance/coupling capacitor calculations?
Phew. That's all the questions for now. Hopefully I shouldn't have to ask that many more when Merlin's preamp book finally arrives
