Hi folks, i just found this old italian farfisa amplifier in the basement, dual EL34 with a rather complex preamp section, ECC83´s, ECL86, EF86..
I ripped everything out of the chassis and made sure the PT and OT are working properly.The PT is giving 500V-CT-500V, 29V with CT and 6.3V at no load!
The amp had a EZ81 tube rectifier, on the same heater winding as the other tubes but i think i just want to go fr a simple diode bridge rectifier on this one.
If i didnt want to use the full 500V-CT-500V power, can i just use one half of those windings and rectify 500V-CT...not sure if i really need that much (close to 1000V with 1N4007 bridge rectifier, no load, of course...) of power?
Opinions more than welcome!!!
I would love to make a simple dual EL34 amplifier on that Farfisa chassis and where possible with the Farfisa parts, lots of mustard caps & all tubes are Telefunken except for the ECL´s wich im not going to use.
I would like to make it having a EF86 and a ECC83 input channel,and simple ECC83 PI.
Maybe a Cut control ala Vox and rotary selectable bass-cut pre-PI.
Problem is that i build quite some amps to date but have really no big experiences in designing circuits from the ground.
