I've seen in a few locations on the webs that 12BH7 has a max plate voltage of 300V, while the 12BH7-A has a max plate voltage of 450V. But the GE data sheet for 12BH7-A has a max plate voltage for Class A1 use as 300V, and 450V for use as a vertical deflection amplifier.
http://www.hifitubes.nl/weblog/wp-co...ic-12bh7-a.pdf
I am currently running one as a Class AB1 P-P output valve, cathode biased, with ~330V plate to cathode, and it seems happy enough so far
My question is three-fold -
Does the 12BH7-A actually have a higher max plate voltage then the 12BH7 for Class A1 amplifier usage?
Is this Class A1 max still the most aplicable one when the 12BH7 is used as a Class AB1 P-P output valve?
How high a plate voltage can they really take without getting uncomfortable ie. has anyone run them higher than 300V and had no problems
Thanks for any and all help
