Commonly, we only have power amount of amp, But when we use power sacling , VVR, or attenuator to reduce the volume of amp , we must know how many attenuation we must have in order to obtain satisfy volume.
-3db means half power, so if we have -12db attenuation. it means we reduce the power to 1/16. by next chart, we can eastimate if the attenuator o.k to you.
A 50 watt amp is *a thousand times too powerful*.
X% louder = 2^log10(P2/P1) * 100%
40 watts is 94% as loud as 50 watts.
30 watts is 86% as loud as 50 watts.
25 watts is 81% as loud as 50 watts.
22 watts is 78% as loud as 50 watts.
20 watts is 76% as loud as 50 watts.
18 watts is 74% as loud as 50 watts.
15 watts is 70% as loud as 50 watts.
12 watts is 65% as loud as 50 watts.
10 watts is 62% as loud as 50 watts.
9 watts is 60% as loud as 50 watts.
8 watts is 56% as loud as 50 watts.
7 watts is 55% as loud as 50 watts.
6 watts is 53% as loud as 50 watts.
5 watts is 50% as loud as 50 watts.
4 watts is 47% as loud as 50 watts.
3 watts is 43% as loud as 50 watts.
2 watts is 38% as loud as 50 watts.
1 watt is 31% as loud as 50 watts.
3/4 watt is 28% as loud as 50 watts.
1/2 watt is 25% as loud as 50 watts.
1/4 watt is 20% as loud as 50 watts.
1/10 watt is 15% as loud as 50 watts.
50mW is 13% as loud as 50 watts
20mW is 10% as loud as 50 watts.
10mW is 8% as loud as 50 watts.
5mW is 6% as loud as 50 watts.
1mW is 4% as loud as 50 watts.
0.5mW is 3% as loud as 50 watts.
0.1mW is 2% as loud as 50 watts.
50uW is 1.6% as loud as 50 watts.
10uW is 1% as loud as 50 watts.
Commonly the sound of 2 w amp is better in home. if you use 30w amp, from last chart
attenuate 12db, it is about 2w, the sound is 44% of 30w amp
Tube Guitar amplifier,effect pedal and studio gear manufacturer kldguitar
