What is the requirement for flameproof resistors.
I have been looking at a few schematics that stipulate flame proof resistors in certain positions, my understanding is that flameproof resistors should be used where the shorting of the resistor to ground or the overload of the resistor could cause the resistor to catch alight.
So I can figure out that the lower value resistors (less than 25k say) in the power supply would have to be very high wattage to cope with a short to ground, so using resistors that are spec’d at a lower wattage for the application is fine as long as they are flame proof in case they get overloaded.
So the question is where is the line or how do we know when a resistor will catch alight?
For example if I have a b+ of 350v and 100k plate resistor off that that plate resistor would need to be rated at at least 1.25w to cope with a short to ground, but that probably wouldn’t cause a 1 watt resistor to catch alight…. would it?
thanks in advance
thanks in advance
