I have a triad transformer I'd like to use for a firefly build. It's rated at 230v 110ma and center tapped (two separate windings) but I'm actually getting 142vac across each winding so it's really 284vac. Problem is I'm getting +390V without load with full wave and +195V full wave CT grounded. The 12au7 is rated for 300 volts on the plate so I'd either need to cut down the B+ or use the +195, which I fear is too low.
Suggestions? Can I use a power resistor in front of the pi filter? is +195 too low?
