This is true, turning the transformers to the proper relative angles has the same effect as greatly increasing the distance between them.
However, you can make any layout work if you know what you are doing.
This amp actually has a little hum from induction between the PT and OT, even though they are at opposite ends of the chassis, because I put them in the "bad" orientation for looks. But luckily when the HT is turned on, the global NFB makes the hum disappear.
I had no trouble from capacitive coupling, even though the input jack is next to the OT and it has 5 gain stages before the PI.
