"Centre biased", do you mean just dialed with the cathode resistor or (hope not) the B+/B- thing ala TubeWorks?
Also, I could please, use some clarification. With the XLR hookup - so we tap into +, just Pin 2? Might need a diagram, though I might draw something up.
Edit: Can we put the output cap on either signal pin?
And don't run unbalanced, tying Pin 1/shield to Pin 3 with phantom power, unless with a cap.
"Phantom powering can cause equipment malfunction or even damage if used with cables or adapters that connect one side of the input to ground, or if certain equipment other than microphones is connected to it."
