Greetings, Can anyone tell me the results of this, tone wise. How does
lowering or raising the amount of voltage a power trans feeds to the amp affect the character & tone of the tube amp. And swapping out a 50 watt trans with a 100 watt trans ?
I recently aquirred a 1972 Marshall JMP model #1987 50 watt head. I have found out the power trans had been replaced with a PT normally designed for a fender twin reverb or showman amp. This trans is sold from NSC [NEW SENSOR CORP.] They told me the high voltage secondary is 690v center tapped at 310 ma with a 50 volt bias tap . filament winding 6.3v at 6 amps. With this being done, how did this affect the original character of the amp. With my BIAS KING bias meter it has 455 volts to the plates biased at-40ma with EL34.
What I want to do now at this point is do want ever I need to do to make this Marshall amp have the best possible tone that will suite MY TASTE. I feel need to most likely change the PT but have some quetions as to what I
need to look for in a replacement trans. So I'm asking for help from anyone
that can guide me in the right direction. It seems that there is a big following to mod later JMP 50'S to JTM 45 plexi amps. I know they used
KT66 tubes as opposed to EL34. Why would it not be a simple tube change
and rebias? And why is there such an attraction to revert back to those
EARLIER AMPS TONE? How are they different?
MERCURY MAGNETICS seems to have a wide variety of PT and OPT available for just this model alone, so I'm trying to get a better understanding of all this in order to make some choices.
Thanks to all that can shed some light on this.
MAY TUBE AMPS NEVER DIE !
Tonerocker
Tonerocker
