Watts?
  • #46
    Just found this post comparing SS watts to tube watts.
    Please let me post my personal onstage experience.
    Shortest (incomplete) answer: they are the same; the speaker , which is a motor (voice coil + magnet) physically driving a mechanical load (cone+other moving parts+air) does not know or care what is feeding voltage into its terminals and supplying the current absorbed by its own internal impedance.
    Then why do Musicians *perceive* the same specified RMS watts as louder when coming from a Tube amp than when coming from an SS one?
    I have personally perceived that too, so if there is some "cheat", I for sure am also falling into it.
    So there must be some Physics reason for it, backing the Musical difference, I don't believe in gremlins or magic.
    I believe that if you hear something different, you must measure *something* different (or at least see something different on a scope screen).
    I will open a can of worms here:
    step by step, along 40 years, I have progressed little bit by little bit until I succeeded into developing and successfully marketing a 300W bass amp which holds its own side by side with a Classic Ampeg SVT (the yardstick by which Bass amps are measured).
    This is not a Lab experiment, my B300 is the most sold high power amp in Argentina, used by the most important bands here, many of which *sold* an Ampeg SVT to buy one of mine.
    Not only that, they come back later for more, or send friends, that must mean something.
    They keep their 8x10" "fridges", though.
    Or , say, a Peavey or Ampeg or Cerwin Vega 2x15" cabinet.
    What's the difference with other, "regular" SS amps (as GK700, Hartke 3500, Peavey DataBass450, Fender 300W) all of which have been replaced with one (or two) of mine?
    1) power device technology is not the cause: I went from 2N3773 (30 years ago) to MJ150xx (20 years ago) to IRFP250 (8 years ago) and the basic sound has not changed (well, MosFets are slightly more "brittle").
    2) Power amp architecture isn't the cause either, I'm a minimalist and still use the most basic Linn structure.
    No current mirrors, symmetrical differential inputs, constant current supplies, embedded OpAmps , etc.
    What is important then?
    3) No short circuit protection.
    They cause all kinds of kinky very unmusical overtones even on proper speaker loads, simply because regular speakers are kinky crazy loads themselves.
    All I use is a current sampler which latch triggers open a speaker relay when it does not like what's happening. It has 3 parts only (well, 4 if you count the relay anti-kick diode).
    4) A *very* "loose" compressor.
    Very different from most, which tightly control power amp input signal and never allow even 1% distortion, nor clipping, mine lets the power amp clip, normally up to 10 or 15%, quite visible on a scope.
    5) It's very "fast" too, so much so that low frequencies "tremolo" modulate mids and highs.
    So much so, that there is some of a "ring modulator" effect, bass notes take some of a "piano string" flavor, similar to Chris Squire's old "Yes" or Deep Purple "Machine head" sounds.
    Beautiful with roundwounds on a Precision Bass.
    The fact that it's quite non linear adds to this effect.
    Did I mention I use a Fet *way* over it's recommended signal range?
    Would you believe 1 to 9V RMS?
    Yes, it becomes *quite* unsymmetrical, even with compensation. Lots of even harmonics.
    6) What does it add up to?:
    * Musicians sometimes drive a very powerful PA type power amp (think QSC900, AB1000 or 1500) straight from my preamp out; after some time they go back to the internal 300W I mentioned, because it "provides more stage presence and projection"
    * They try to use it very loud "because it growls" or "it gets angry" ... similar to what Tube amps do.
    * It never "farts", I not only don't boost bass, but even slightly cut it with a soft slope below 100Hz.
    Anyway it has very low damping (value=1) so cabinets have a natural 6dB peak at resonance, at which frequency they are also *very* efficient.
    I don't try to (equalize-boost) bass which the cabinet can't reproduce by definition (a recipe for disaster); on the other way this head auto-adjusts to whatever good response the cabinet has.
    The relatively high internal impedance means that regular bass speakers sound somewhat sharper in the higher frequencies, while at the same time looser and underdamped around resonance.
    I'll try to picture and post some waveforms, which clearly do not look like your regular SS amp ones.
    I must have been doing something well, because my customer's database *is* the Who's Who of Argentine Rock.
    These names are not known outside Argentina and perhaps surrounding Countries, but I have supplied these amplifiers to: Manal, Vox Dei, Raúl Porchetto, Pappo, La Torre (Patricia Sosa), Sandra Mihanovich, Les Luthiers, Sandro, Charly García, Nito Mestre, Crucis, Pastoral, Sergio Denis, Los Auténticos Decadentes, Hellion, Rata Blanca, Raúl Giecco, Dr Rock, Mercedes Sosa, Beba Pugliese, La Renga, Almafuerte, V8, and thousands of others.
    What does all this boil down to?:
    I have put my B300 side by side with an Ampeg SVT, each driving an 8x10", same signal going into both, volume up until sound starts to growl, and they stand shoulder to shoulder as equal brothers, although each one has its own characteristic "signature".
    Other similar SS amps as the ones I mentioned before either lack presence and punch, don't "cut through" (the ones with tight compressors) *or* go all the way, either fart or sound like buzzsaws ... or both. (the uncompressed ones).
    These *can* be heard, or cut through ... but you'd prefer them dissappearing.
    EDIT: before somebody points out that "(electrical) watts can't be heard", I hope I made it clear that I am comparing *electrical* watts driving the same enclosures, which thus have the same conversion efficiency by definition.
    • #47
      juan,
      what is the power output of your b300? into different loads? at 5% thd? what is it when fully cranked?
      most importantly, if we are to use steven's suggestion, how much does it weigh?
      • #48
        Hi kg.
        It's somewhat over 200W into 8 ohms and 300W into 4 ohms, at visible clipping.
        More important: power rails are +/- 70V and filtering is just adequate 4700uF per side.
        I clearly see some 5Vpp ripple @ 50Hz modulating the wave tops, it's part of the sound.
        Never *measured* distortion, I find a good match between what I see on the scope and what I hear, fine with me.
        It never buzzes or farts, it just growls, hope the difference is clear.
        Whenever possible I'll record and post some MP3s.
        The waveform is visibly "rounded" way before reaching clipping, that's typical of FET compressors; in this case it works to my advantage.
        In a way, I think it might be compared to a Lab L5, set up by, say, BBKing to his liking, and then used with bass, driving an approppriate cabinet.
        Not done on purpose, of course, this all came from obsessively tuning by ear a simple compressor since around 1972, when I *had* to switch from tubes to SS (long story) and noticed SS Bass amps were *unusable* without them.
        The very short time constants (and the intermodulation that caused) came because I *hated* the typical response of 70's technology compressors: a sharp "slap" --> a good fraction of a second of silence --> the note sound painfully rising to a steady volume, as if swelling up with a volume pedal. Ugh !!
        Even modern day ones, such as SWR's show that trait, that's why they can be switched off.
        Mine can't be switched off, the user can't change attack, release, nothing.
        Don't understand your reference to Steven.
        The sound is as I described; if you talk of physical weight, it must be around 12 to 15Kg, the cabinet being a good part of it.
        I'm developing a SMPS for it, but one which is not tight or over regulated, I just need a lighter version of my EI iron power transformer which behaves exactly as it does.
        Well, that's about it.
        • #49
          I believe he was referring to "Conner's law", that loudness is inversely proportional to the number of watts per pound. I don't think cabinet counts and will leave it to Steve to give the exact ratio's, whether the proportion is linear or logarithmic, and most importantly, whether having to move one's own gear has any placebo effect on this.http://music-electronics-forum.com/i...ilies/wink.png
          • #50
            tee hee. just a little joke:
            Originally posted by Steve Conner View Post
            So, to sum up, according to my theory, watts is the wrong unit of loudness, it should be pounds. A 50lb transistor amp should be as loud or louder than a 50lb tube one.
            • #51
              Loudness is directly proportional to Pounds, Dollars and Euros.
              Valvulados
              • #52
                A fifty pound transistor should be louder than a 50 dollar one, that is, if the dollar continues to sink a 50 Japanese yen transistor may well end up being louder than anything produced in the West.
                Valvulados
                • #53
                  having been playing blues/rock bass guitar for 30-40 years, and repairing the stuff along the way, (also teaching electronics for 7 years) there is a difference between SPL (sound pressure levels) and wattage. First off, you need to measure your power output of the amp. get a multimeter and put is AC mode and read the voltage across a 4 ohm resistor. (I made one using a vienna sauage can and wrapping number 14 wire up to 4 ohms, place it in a picther of water). Make sure that your outputs total power dis and heat sink can handle the heat.... the turn the amp up max with a patch cord in and touch the other end to produce an AC hum. The AC voltage should be around 30-50 volts. Multiply by itself (square) and divide by the resistance (4 ohm) This is your continuous wattage output...RMS. Rated amp outputs are rated in BS in order to get you to buy them....Remember, every time you double your power you are only increasing by 3db! 10x increase = 10dbs. SPL if a function of your speaker system..(loudness) .personally I would put more money into the speakers. The larger the voice coil the more SPL. Bass ported (reflex) and folded horns produce higher SPLs.
                  • #54
                    Well, let's see, googling a little shows:
                    Technical Data
                    Copper Wire Resistance Charts: American Wire Gauge (AWG)
                    COPPER WIRE RESISTANCE (OHMS PER 1000' OF WIRE)
                    WIRE GAUGE (AWG)
                    18 16 14 12
                    6.385 4.016 2.525 2.057
                    So we are talking 1600 feet of #14 wire, wound around a sausage can (I wonder how you fit that much wire there, but maybe I'm anally obsessive with irrelevant detail).
                    It would at least be basketball size.
                    I can't call that a resistor, but an inductor.
                    The over one thousand turn winding would sure qualify as such.
                    No comment.
                    Well, the Math is fine.
                    I see you regularly work with mighty loud amps.
                    30VAC into 4 ohms means 225W RMS ; 50VAC mean 625W RMS.
                    Good to know.
                    Now I'll stop wasting money on iron and magnets and go for silly large voice coils instead.
                    • #55
                      May I introduce two small doses of science?
                      1) If you have a 55 volt rail and a class D "H" bridge with beefy mosfets we can assume that we're using all of that 55 volts. Assuming we're amplifying a bass guitar and the waveform is more or less a sine wave it's the equivalent of having +-55 volt rails. 55+55=110. 110 volts peak to peak = 38.9 volts rms sine (divide 110 by 2.828).
                      38.9*38.9/8= 189 watts into 8 ohms
                      38.9*38.9/4= 378 watts into 4 ohms
                      I know that such an amp could produce a lot more if it were amplifying a square wave but we're talking about real-world musical conditions which means a sine wave- because you can't run an amp into the rails and expect it to reproduce all of the harmonics of a musical instrument. I think this needs to be taken into account when making calculations. This science gets much fuzzier at the limits when you include the varying impedance of a speaker and the interaction of an output transformer and its inductance.
                      2) There was a paper produced by the AES back in the 70's or 80's comparing the distortion behavior of tube and solid state devices. All arguments of real world power output aside, there is a proven science to tube clipping behavior. When solid state components are pushed into distortion it's immediately evident as distortion. Per the testing in the document the harmonic structure of a distorting tube is interpreted by the human ear as additional loudness information. It's not that tubes ARE louder, it's that they SOUND louder.
                      Now, an editorial.
                      For the record, if anyone doubts that tubes SOUND louder, set up an old school tube SVT and an SWR 300 side by side into identical 4 ohm cabinets. They have roughly the same wattage but I promise the SVT will blow the pants off of the SWR.
                      I love my SWR but it's no SVT!
                      In other words I'm with KG and Steve on this one.
                      jamie
                      • #56
                        My bass player friends tell me that the conventional wisdom among bassists is that a bass player needs 10X the power rating of the guitarist.
                        • #57
                          80% of cheap car audio systems which announce "1000 Watts" are just flat out lies. Unless you elevate the 12 VDC rail, you don't get more than 36 WRMS off a "regular" car receiver. Pioneer has this very clear on their sets, you'll notice they are almost all rated at 35 WRMS. Any higher power amplifiers that aren't a complete fraud must have step up DC-DC converters in them.
                          Valvulados
                          • #58
                            Let me guess, this AES article was written by Russell O. Hamm...?
                            • #59
                              Just adding:the article is very good, and, unusual in many things which are repeated ad nauseam on the Net, based on actual experiment with real world products, but to understand it properly let's not forget that it referred to various Tube or SS Microphone Preamps, quite unrelated to any Power Amp.
                              Reading it carefully, what it really compares is open loop vs low feedback vs high feedback preamps, with higher feedback ones producing sharper distortion thresholds (and clipped waveform edges) than lower feedback ones, which sounded more "organic", just to use a fashionable term.
                              This fact had more influence on the final sound than the actual device used.
                              Not denying that typical Tube and SS`stages did clip and sound different.
                              • #60
                                Watts is power. Speakers convert watts into SPL,measured pressure differences in air. Different speakers convert differently.
                                Loudness happens in your head. The same peak to peak/average/rms/etc. SPL can impress you as having different loudnesses depending on
                                - the frequency content of the signal
                                - the generic frequency response of the human hearing mechanism (look up Fletcher-Munson)
                                - the specific frequency response of your ears (how many loud concerts did you play/attend?)
                                - your brain's experience and expectations
