I've recently got a hold of some nifty pentode tubes (1LG5, 1LC5, lots of variants) that were designed to be used in portable radios and were actually intended to run at 45v plate/screen (Heater current is 50mA at 1.4v). Pretty much a perfect fit for my pre-amp powered off a laptop supply, and gives me an opportunity to fiddle with pentodes.
Usually, I see that resistors are included to drop the voltage down to acceptable levels, and/or to make sure the screen doesn't melt... In my case, neither is of concern, so I'm assuming I just connect B+ straight to screen (I wouldn't need a bypass cap, because no screen resistor is present, right?).
With B+ straight to the screen, it would seem no screen compression is going to be present, but say if I wanted to include this, what would be the best option for incorporating it? Are there any fancy screen voltage modulating circuits out there, or should I just drop the screen voltage with a resistor (not sure it would like this...) to say, 30 volts. Another option is to simply voltage double the B+ supply, then drop the screen voltage with a resistor down to 45v.
