If you want to add filter caps to a circuit, but do not want to drop any (appreciable amount of) voltage; how do you determine what value resistor to use.? I have mulled this over in my head, but I am not sure what to do.
For example, in the schem below, if you want the plates of V1 to have their own filter cap, what value (how do you figure it out.?) resistor would you use to separate the nodes.? Could I just use a 1 ohm, 10 ohm, 100 ohm resistor.? I just want to separate the caps, not drop voltage. Hope you guys understand what it is I am trying to ask.
Thank You
Thank You
