I understand how if a rect tube shorts out then you have ac to the filter caps and they can blow and then blow the PT because the diodes will not allow the voltage to flow back to the PT HT windings . What I don't understand is how the diode can keep the amp working and for two reasons that have yet to be explained. If the filter caps blow you are done anyway , and lets say the caps don't blow how does the HT voltage reach the heaters or rather find a path to the B+ ?
The rect tube changes a/c to d/c now wouldn't it sort of depend on what shorted in the rect tube to begin with?
What am I missing here? I have had a rect tube long ago short in a sf champ and the main fuse blew . I put in another fuse and powered up and the fuse blew again. I went to a local dealer who sold amps and guitar and all the varied stuff and he told me I needed a new 5Y3 . I put it in with a new fuse amp worked.
So just what part of a rect tube shorts in the first place . Fender never put diodes in the HT leads and if not why not . I have not read about adding diodes even on re -issue models of the old point to point fender amps that still use rect tubes. I am certain fender knew about tubes shorting out and that they would not risk replacing PT's for the cost of a few diodes
