I have a couple of Fender PA 100s that are 100w and 4 ohms.
I want to combine them together into a 200w 8 ohm bass amp.
It appears there are 2 ways to do this.
METHOD 1 (Series Transformers)
1. Connect the inputs of the first channels of Amp-A and Amp-B together.
1.A. Plug one end of a 1/4” phone cable into the input of the first channel of Amp-A.
1.B. Plug the other end of the 1/4” phone cable into the input of the first channel of Amp-B.
1.C. Eliminate any ground loops that result.
1.D. Use the remaining unused jack in the first channel of either amp as the input to the combined amps.
2. Connect the secondaries of the output transformers of Amp-A and Amp-B in series with each other.
2.A. Remove the terminal from ground on the secondary of the output transformer of Amp-A and label it T1.
2.B. Label the other terminal on the secondary of the output transformer of Amp-A as T2.
2.C. Label the terminals on the output transformer of Amp-B the same way as as they are labeled in Amp-A.
2.D. Remove The NFB wire in Amp-A from T2 and connect it to T2 of Amp-B.
2.E. Connect T1 of Amp-A to T2 of Amp-B.
3. Connect an 8 ohm speaker cabinet to the combined amps.
3.A. Connect one wire of an 8 ohm speaker cabinet to T2 of Amp-A.
3.B. Connect the other wire of the speaker cabinet to T1 of Amp-B.
METHOD 2 (Bridging)
1. Use a modified version of Step 1 of Method 1.
1.A. Instead of using a simple phone cable to connect the inputs of the two amps together as was used in Step 1 of Method 1, use an inverting stomp-box pedal to connect the inputs of the two amps together.
1.A.i. Plug one end of a 1/4” phone cable into the input of the first channel of Amp-A.
1.A.ii. Plug the other end of the 1/4” phone cable into the input of the inverting stomp-box pedal.
1.A.iii. Plug one end of another 1/4” phone cable into the the output of the inverting stomp-box pedal.
1.A.iv. Plug the other end of this 1/4” phone cable into the input of the first channel of Amp-B.
1.A.v. An alternative to using an inverting stomp-box pedal is to connect the inputs of the two amps together the way it is done in Step 1 in Method 1. Then modify an unused channel in Amp-B and use it to invert the signal in the first channel of Amp-B.
2. Label the terminals of the transformers the same way as was done in Step 2 of Method 1, but do not do any of the modifications that were done in Step 2 of Method 1.
3.B. Connect the other wire of the speaker cabinet to T2 of Amp-B.
FUNCTIONALITY?
Q1.A. Will both methods work?
Q1.B. Are there any other methods that will work?
Q1.C. Which method is best? Why?
NFB ISSUES?
Q2.A. For Method 1, will the nonlinearity correction be acceptable for Amp-A even though Amp-A is using Amp-B's NFB signal.
Q2.B. For Method 2, will the NFB in either amp be affected?
OSCILLATION ISSUES?
Q3.A. Is Method 1 prone to spurious oscillations? If so, how can they be prevented?
Q3.B. Is Method 2 prone to spurious oscillations? If so, how can they be prevented?
NOISE ISSUES?
Q4.A. Will Method 1 cause the amps to be noisy?
Q4.B. Will Method 2 cause the amps to be noisy?
OTHER ISSUES?
Q5. Are there any other issues to discuss?
METHOD 2 (Bridging)
FUNCTIONALITY?
NFB ISSUES?
OSCILLATION ISSUES?
NOISE ISSUES?
OTHER ISSUES?
